cain Posted March 16, 2006 Share Posted March 16, 2006 Do I need a network license to network render? I have gone through the help files and it says to launch full viz on main computer/server and install compact version on the other computers. When I insert the provided cd and start installing on the other computers in the office there is no compact version. Is this something I must pay for? I am using viz 2006. Thanks Link to comment Share on other sites More sharing options...
lambros Posted March 16, 2006 Share Posted March 16, 2006 Nope, a network license is used to transfer a license within a network. To use network render, just install viz on all computers. Then use the backburner to launch a network rendering, i.e. run manager.exe and monitor.exe in the host computer and run server.exe on all other computers (you don't have to launch viz on the othe computers on your own) Link to comment Share on other sites More sharing options...
cain Posted March 16, 2006 Author Share Posted March 16, 2006 Thank you Lambros. My other questions is, Can I still apply this with mental ray? Link to comment Share on other sites More sharing options...
lambros Posted March 17, 2006 Share Posted March 17, 2006 As far as I remember, mental ray has infinite network licenses with the latest versions of max, I suppose that the same goes for viz. I do not use mental ray at all, so I cannot verify this for you. I think that a visit at the autodesk site will clarify things for you! Link to comment Share on other sites More sharing options...
marvins_dad Posted March 23, 2006 Share Posted March 23, 2006 Recently went round and round with Autodesk about the Mental Ray deal with Viz. Viz 2006 only has license for Mental Ray on your workstation...no extra nodes. Max 8 has unlimited... Viz 2007 - they couldn't say, but said it would be similar to Max, however I just looked at that documentation that was linked in the 2007 thread and it states 8 render nodes in 2007. Link to comment Share on other sites More sharing options...
Arkkitekktura Posted June 6, 2006 Share Posted June 6, 2006 What is the main diferences between VIZ 2007 and MAX 8 any particular reason why chosse either if you want to use primarily for ArchViz? Link to comment Share on other sites More sharing options...
Brian Cassil Posted June 6, 2006 Share Posted June 6, 2006 The biggest difference between max and viz is in viz you can only animate the transforms (move rotate scale) at the object level, and a few other simple controllers. Wheather this is enough for arch viz is completely up to the user. Link to comment Share on other sites More sharing options...
