anvaraziz Posted March 18, 2006 Share Posted March 18, 2006 friends, i have one doubt regarding flyaround animations for exteriors,, regarding environment. for animations , how u guys used to merge sky with landscape at a far distance...? here r some frames from one test im doing, i need to give a good landscape after those blocks and merge it with sky at a far distance. im looking for this kind of look LINK pls give me some advices regarding this,,,,,,,,, thanks in advance.... Link to comment Share on other sites More sharing options...
Christopher Nichols Posted March 18, 2006 Share Posted March 18, 2006 In features this is usually done with a pan and tile system of a matt painting. Link to comment Share on other sites More sharing options...
DennisHolland Posted March 18, 2006 Share Posted March 18, 2006 There was an article about landscaping for anims recently. Check the Groundwiz website (google or http://www.gugila.com). You must use a plug to achive the endless horizon look otherwise your anim will be quite huge (polygon-wise).... If you want to do an anim that only goes up and move around a bit (instead of going the full 360gr) then you can use a city/forrest backsplash like I did in my promo here check the vid on the homepage. Regards, Dennis Link to comment Share on other sites More sharing options...
anvaraziz Posted March 18, 2006 Author Share Posted March 18, 2006 In features this is usually done with a pan and tile system of a matt painting. can u pls explain that work flow... Link to comment Share on other sites More sharing options...
anvaraziz Posted March 18, 2006 Author Share Posted March 18, 2006 Dennis - Groundwiz look good, let me give a try... here is the vid that im testing.. http://www.mukks.com/others/TEST.avi (1MB divx) Link to comment Share on other sites More sharing options...
DennisHolland Posted March 18, 2006 Share Posted March 18, 2006 That is a cool clip Anvar! First thought; i'd say start the first 30 fr. slower and pump you speed quite some to the end. I like the movement, real smooth... For this clip you could use a bowl and a citytexture but then you got to have some luck and a few tests... Good luck, post your wip's Dennis Link to comment Share on other sites More sharing options...
anvaraziz Posted March 18, 2006 Author Share Posted March 18, 2006 thanks dennis,,, ill keep postin wip.. now im doing some test with Groundwiz, its good for a hill type background,,, Link to comment Share on other sites More sharing options...
Christopher Nichols Posted March 18, 2006 Share Posted March 18, 2006 can u pls explain that work flow... Someone paints a background (sometimes based on a photograph) the camera is imported in the compositing package (that needs to support 3d cameras)... it is fairly involved and usually involves a very talented matt painter like on the ones listed here: http://www.mattepainting.org/index.php?categoryid=13&p16_sectionid=2 Then you will need to composit it in a way that is simlar to the way Rob shows you here: http://www.thegnomonworkshop.com/dvds/rne02.html Link to comment Share on other sites More sharing options...
anvaraziz Posted March 19, 2006 Author Share Posted March 19, 2006 thanks chris, but for archvis, using packages like nuke and all... ?, any way ill give a try with AE using some good images insted of mattepainting,, im soo poor in Painting,,,, while searching i got a cool article regarding blending landscapes and horizon. here is the link but i didnt understand wht he says for the second option... Link to comment Share on other sites More sharing options...
jonel Posted March 19, 2006 Share Posted March 19, 2006 try put some blured opacity map on the ground plane. This should give you a nice gradient between the ground and sky/background map. Link to comment Share on other sites More sharing options...
Hao La Posted March 19, 2006 Share Posted March 19, 2006 matte painting is the best choice Link to comment Share on other sites More sharing options...
anvaraziz Posted March 20, 2006 Author Share Posted March 20, 2006 jonel - thanks buddy,by using opacity maps never worked for me,, i tried that too,, but its not giving depth,. Link to comment Share on other sites More sharing options...
jonel Posted March 20, 2006 Share Posted March 20, 2006 for depth, i would use z-depth pass (or fake with fallof map, fog, whatever suites) for masking the white solid layer above rendered image (with GI, like the first example). Link to comment Share on other sites More sharing options...
anvaraziz Posted March 21, 2006 Author Share Posted March 21, 2006 hey that Z depth stuff looks so cool... thanks jonel. its great to add fog on depth... thats a cool idea... Link to comment Share on other sites More sharing options...
