bripatfan Posted March 18, 2006 Share Posted March 18, 2006 Hello- First post. New to Vray and I am coming across a major problem that hopefully someone can help me with. I have a Vray night exterior lit how I want it to render for one static image. Accordingly I calculated a 800 x 600p irradiance map with this lighting setup. Using this irradiance map I attempted to Network Render out an image of 2x the size (1600x1200) by using the calculated IR map and increasing the Calc pass interp samples and increasing the quality of the min and max rate settings in the irradiance map parameters. Even though when I preview out the render (region render small sections) it renders correctly it renders out WAY too dark when I render the entire image. Sounds like an irradiance map issue but are there any thoughts on this? Any info would be greatly appreciated. Here are the correct and incorrect images Link to comment Share on other sites More sharing options...
Tim Saunders Posted March 18, 2006 Share Posted March 18, 2006 What type of network rendering are you doing? I'm wondering if your vray isn't working on the other nodes, therefor your materials aren't shading correctly. Link to comment Share on other sites More sharing options...
bripatfan Posted March 18, 2006 Author Share Posted March 18, 2006 Timothy, Thanks for your response... I am using Backburner for 3ds max 7. I thought about the possiblity that the Network Rendering was causing problems but I dismissed it assuming it was a Irradiance Map issue. But you might be right because everytime I region render large sections I DO NOT network render and the images turn out correct. Only when I render out entire images do I use the network rendering and the images turn out dark. Have you encountered problems before with Network Rendering using Irradiance Maps? Link to comment Share on other sites More sharing options...
Fran Posted March 18, 2006 Share Posted March 18, 2006 Is the path to your irradiance map a network address ie "\\computername\irradiance map name"? Link to comment Share on other sites More sharing options...
kippu Posted March 18, 2006 Share Posted March 18, 2006 as fran said .. i guess the slaves are not getting the irradiance map .. Link to comment Share on other sites More sharing options...
bripatfan Posted March 19, 2006 Author Share Posted March 19, 2006 That might be right...I dont think the Irradiance map is linked through the network neighborhood but instead linked directly from a shared drive throughout the office. I will try a different render linking the IR map through the network neighborhood and see if that fixes the problem. Thanks for the responses... Link to comment Share on other sites More sharing options...
