Gander0 Posted March 20, 2006 Share Posted March 20, 2006 Right I'm stuggling with this.... Have calibrated my monitors using Spyder to D50/1.8 and have gotten over the whole pink thing. My problem is with photoshop in Adobe RGB (1998) mode. The issue is that when I bring my nice rendered images in from Max for post production they seem to be MUCH darker, this is the same for sRGB, the only profile I can assign an image for it to get close to max output is Colormatch RGB..... Can someone explain? Do I have to tell max to use a profile? Or should I be using Colormatch RGB in my Photoshop color settings (Have been trying to follow Jeffs instructions) Cheers! Link to comment Share on other sites More sharing options...
AJLynn Posted March 21, 2006 Share Posted March 21, 2006 This is because Max doesn't observe the sRGB profile. There are a few ways to correct this - adjust in Photoshop, change the Max gamma settings or do a curve correction (e.g. in Vray frame buffer if you have Vray). Chris Nichols has talked about this a lot and posted this link a while bck: http://throb.net/site_main/LinearWorkflow.html Link to comment Share on other sites More sharing options...
Gander0 Posted March 21, 2006 Author Share Posted March 21, 2006 Think thats probably what i'm after...Many thanks! Link to comment Share on other sites More sharing options...
