dvi conections on crt and lcd
I have a dell 2001fp lcd monitor and ibm 21" flat screen crt monitor both with a DVI plug and I cant make it work with my wildcat 6110 videocard someone knows why? or experimented something similar?
the only way to make it work is with the rgb plug but both monitors are profesionals and i think it should work better with dvi conections.
also id tried a geforce ti 4800 with a dvi and rgb and only works with the rgb
signal is comming from the videocard cause when i use a dvi to rgb adapter signal apears.
any help??
I get this from 3dlabs:
Dear Ever
Contact the manufacturer of your monitors and ask them if their monitors
sends an ident signal to the gfx card through the DVI cable.
The 3DLabs cards require this ident signal in order to display anything
on your monitors.
Someone had this issue???
