John Martin Posted March 22, 2006 Share Posted March 22, 2006 Hi all, I have a question concerning the Acme and Belden brick designers. I am doing a rendering that is going to require extensive use of brick and I want to use these programs to make the material maps. The problem is that every time I try to make a make a map the tiling is off. I can never get it to make a map that will tile properly. Say I am making a map that is 4 bricks high and 4 wide. I always end up with a map that is not quite that leaving a half brick at the end of a row so that when it tiles there is an obvious joint. I am at a loss on how to fix this problem. I do not want to make a map of the entire wall if I can help it. Any help is appreciated. See the attached image for my problem. You can ignore the colors if there is a variance as I can fix that. It was built as a custom size of 4 bricks high and 4 wide which SHOULD end up with 2 rows with full bricks and 2 rows with half bricks at the ends. John Link to comment Share on other sites More sharing options...
Frosty Posted March 22, 2006 Share Posted March 22, 2006 I've found that those apps require some PS work on the maps after they are created. Its a great starting point tho. Link to comment Share on other sites More sharing options...
ShaunDon Posted March 22, 2006 Share Posted March 22, 2006 I've noticed this too, John. I played for over a half hour one day trying to find a way to make it work. I gave up and now I just produce as large a map as the program will output then crop it appropriately in Photoshop so that it's tileable. The images Acme outputs are usually so large I need to scale them down anyway. Shaun Link to comment Share on other sites More sharing options...
Chad Warner Posted March 22, 2006 Share Posted March 22, 2006 If you are using viz/max you can crop the image in there as well. (under bitmap parameters, cropping/placement) Link to comment Share on other sites More sharing options...
BobM Posted March 22, 2006 Share Posted March 22, 2006 If your map was 4 bricks high by 4 brick wide it would work you are 4 bricks high by 4.5 brick wide. Lose half a brick and a joint on the right hand side and it would work I think as stated your could do this by cropping the image. Link to comment Share on other sites More sharing options...
BobM Posted March 22, 2006 Share Posted March 22, 2006 Sorry lose the joint on the right hand side and keep on the left Link to comment Share on other sites More sharing options...
