Buttman Posted March 30, 2006 Share Posted March 30, 2006 I produced my Cad work into PDF file and loaded up into Photoshop, but the size of the drawing suddenly changed. I set it A2 size paper in PDF file and same size in Photoshop but it won't fit. Any ideas to solve this? Link to comment Share on other sites More sharing options...
C.Vestal Posted March 30, 2006 Share Posted March 30, 2006 I am assuming that your pdf is contains vector data. I always up the ppi/resolution when opening in photoshop. Then resize down to the size you want by using the "image size" dialog in photoshop. Link to comment Share on other sites More sharing options...
Buttman Posted March 31, 2006 Author Share Posted March 31, 2006 How do I use "ppi/resolution" in photoshop? Link to comment Share on other sites More sharing options...
Jeff Mottle Posted March 31, 2006 Share Posted March 31, 2006 How do I use "ppi/resolution" in photoshop? DPI is often wrongly used in place of PPI. You use PPI in digital work and DPI for print work. Photoshop only lists it as DPI for some reason although they should know better. If you want to read some good articles about the difference these are pretty good: http://www.tildefrugal.net/photo/dpi.php http://www.design215.com/toolbox/print_guide.php http://graphicdesign.about.com/library/weekly/aa070998.htm Link to comment Share on other sites More sharing options...
Buttman Posted March 31, 2006 Author Share Posted March 31, 2006 Ok, this is not helping me. Link to comment Share on other sites More sharing options...
