Robeast Posted March 30, 2006 Share Posted March 30, 2006 Ne guy here... I've been trying to render an animation and have to stop the rendering every once and a while. I'm rendering frames so I can put them together using the RAM player. This lets me pick up from where I left off, but I have to rename the files b/c VIZ starts numbering the frames with 0001. Is there any way to have VIZ start numbering frames where it left off or at least choose the first frame number? Otherwise, I end up changing a hundred file names. Thanks, Link to comment Share on other sites More sharing options...
Arnold Sher Posted March 30, 2006 Share Posted March 30, 2006 that is very strange...I do not know about viz but max does not do that... All you do is click on range select from which frame you want to which one you want to end it, name the file such "bathroom" without adding any numbers and it will keep on going just the way you've selected it.. Link to comment Share on other sites More sharing options...
RAYMOND Posted March 31, 2006 Share Posted March 31, 2006 have you tried the options in the render menu i often redo a set of frames like 101-200 when 1-99 are ok Link to comment Share on other sites More sharing options...
