distributed renderings with viz and vray
vTay
salam all
i just wanna try a network ditributed renderings with my two collugues in the university
we have 3 pc each one have an educational license of viz 2006 and individual licences of vray adv 1.45.
can any one give me some tricks or notes about this process????
This pretty much spells it out http://www.spot3d.com/vray/help/VRayHelp150beta/distributed_rendering.htm
If you have any problems, it may be the vraydummy60.max file. The one that comes with vray didn't work when I ran Dr with Viz05 and Vray 1.47.03. But it may not be an issue with your releases. If it is, copy an existing backburner.max file from a previous network render, and paste it in the root folder. Then rename it as vraydummy60.max. That should fix the problem if you have it, but like I said, I'm running different versions than you, so it may not be an issue.
  • 2 weeks later...
