glass masonry blocks
marchitecture
I have very little time and I am relatively new to the program, but I need to know the most efficient way to build and render glass blocks as a solid wall.Would I build the entire wall and add material or would I build one block.
Also, what would be the best way to add several oak trees without making the rendering time rediculous, Where should I get the tree from.
Thanks a million
Marchitecture
glass block walls ..... try making a box and putting a texture and play with refraction or make one block and instance it all over the wall... whichever you find it easier
oak trees ... i suggest using a map and using photoshop or using them with opacity to render
