antonio_frias Posted April 7, 2006 Share Posted April 7, 2006 This morning I tried to open an Autocad 2006 dwg file and I got a message saying that there was a problem with my file and that I had to try to recover it using the RECOVER command. When I did this I got the following message: Reading Handle 171763 Object type AcDbHatch Error 13 (eUnknown handle) object discarded 10 seconds later Autocad crashes! I noticed that the error had something to do with hatches so I tried to open my file partially leaving out my hatch layers. The problem is that when I try to open my file partially Autocad opens a new blank drawing and doesn't even open the window where I can choose my layers. Does anybody know of a way to recover my file or is it lost forever? Link to comment Share on other sites More sharing options...
JamesTaylor Posted April 7, 2006 Share Posted April 7, 2006 how about the auto back up file? Link to comment Share on other sites More sharing options...
antonio_frias Posted April 7, 2006 Author Share Posted April 7, 2006 I tried that! I renamed it into a DWG file but I had the same problem. They were both saved at the same time, that is, when I shut down my workstation last night Link to comment Share on other sites More sharing options...
rmaister Posted April 10, 2006 Share Posted April 10, 2006 I don´t know if Autocad 2006 still uses the .SV$ backup, it´s from the automatic save option (R11 - 2004), so if you have it active it should have saved a copy. You only need to rename the file extension. Saludos Rodrigo Link to comment Share on other sites More sharing options...
Fernando Lino Posted July 20, 2011 Share Posted July 20, 2011 -Go to open, inside there is an option named "Partial open" maybe you would be able to extract some information. -another option is open a new drawing from scratch and xref the file that you want to recover...if you get something "bind" it -import the file to another application such as Sketchup, MAX, Rhino, etc....and export it back to CAD (at least you could get something ). -see if the file has been opened from a another computer in your network and check the temp files, backup files, etc...go under options>files to see where they are located. Good luck Fernando Link to comment Share on other sites More sharing options...
