qq3 Posted April 7, 2006 Share Posted April 7, 2006 hello I have problems with mental ray in Viz ... i cant render with distribuitet bucket in my own net. I attatched in host file ..3 computers : pcp18, pcp25, pcp27. I have errors like this : MSG 0.0 error 011329: mi-ray/tcp: not a service (check %SystemRoot%\system32\drivers\etc\services) MSG 0.0 warn 012219: using fallback inet service 7003 MSG 0.0 error 011229: could not connect to host:port pcp25:7003 - No connection could be made because the target machine actively refused it. MSG 0.0 error 011706: cannot add host pcp25:7003 MSG 0.0 error 011227: unknown hostname pcp27 - check /etc/hosts (or alike) MSG 0.0 error 011706: cannot add host pcp27:7003 MSG 0.0 error 011229: could not connect to host:port pcp18:7003 - A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. MSG 0.0 error 011706: cannot add host pcp18:7003 if anyone know what to do ... ? any solution ? thx Q Link to comment Share on other sites More sharing options...
theqball Posted April 14, 2006 Share Posted April 14, 2006 Usually you just need to open the port up in the windows firewall settings. If you are using another software firewall then you also need to open that port up. Link to comment Share on other sites More sharing options...
