anindia Posted April 7, 2006 Share Posted April 7, 2006 hi all, can anybody tell me where form i get animated water maps with alpha channels? i urgently need it for a walk through development. help me pls. Link to comment Share on other sites More sharing options...
Arnold Sher Posted April 7, 2006 Share Posted April 7, 2006 http://www.doschdesign.com Link to comment Share on other sites More sharing options...
John Dollus Posted April 9, 2006 Share Posted April 9, 2006 http://www.lysator.liu.se/~kand/caustics/ Can be used for displacement, bump, opacity, etc... Link to comment Share on other sites More sharing options...
jvlive Posted April 10, 2006 Share Posted April 10, 2006 hey, that caustics generator looks cool. thanks! Link to comment Share on other sites More sharing options...
anindia Posted April 10, 2006 Author Share Posted April 10, 2006 that thing is good indeed, but i want something like cascade of water and fountain, can anybody help me Link to comment Share on other sites More sharing options...
John Dollus Posted April 12, 2006 Share Posted April 12, 2006 Oh, I understand. How about this: http://www.cgarchitect.com/vb/archive/index.php?t-10869.html Which version of Max do you have? There was a nice example waterfall scene included back when they added particle motion blur - maybe Max 2 or 3? Link to comment Share on other sites More sharing options...
anindia Posted April 12, 2006 Author Share Posted April 12, 2006 hi john, thanks for ur reply. but i need some kind of animated map. i ve seen it somewhere in the net but i couldn't remember actually. using an animated map makes the file more smooth and realistic. the rendering time also becomes less. thanks. Link to comment Share on other sites More sharing options...
John Dollus Posted April 12, 2006 Share Posted April 12, 2006 Here is another one that I think is closer to what you want but it's till particles. http://www.cgarchitect.com/resources/tutorials/SM_waterfall.pdf You can achieve a similar effect through maps-only by doing the following: 1. Create a plane for the weir overflow. 2. In the material editor, go into the opacity slot and add a noise map (either regular or fractal works pretty good). 3. Turn off the show end result toggle so you see the whole map and not a sphere. 4. In the Noise submap, turn down the Tiling for Y direction down to around .2 or so and turn up the tiling for X to 3-ish. 5. You should see vertical streaks in the material window at this point 6. To get a flowing effect, animate the Y offset. 7. You can add either add another noise map in the diffuse slot to vary the color a bit or duplicate the plane geometry and assign a duplicate of the material with a different phase in the noise slot to mix things up a bit. This is just a very quick step by step to get you going. You can get some nice effects by using it in the refraction/reflection slot depending on what render engine you are using. Link to comment Share on other sites More sharing options...
Chad Warner Posted June 21, 2006 Share Posted June 21, 2006 http://www.lysator.liu.se/~kand/caustics/ Can be used for displacement, bump, opacity, etc... Did anyone download this program that wants to send it to me? The link isn't working right now and I could really use it for an indoor pool. chad@bluelime.com Thanks Link to comment Share on other sites More sharing options...
Ernest Burden III Posted June 21, 2006 Share Posted June 21, 2006 Did anyone download this program that wants to send it to me? I sent you the file that I believe came from that link. I never tried it, just saved it 'in case'. Link to comment Share on other sites More sharing options...
Chad Warner Posted June 21, 2006 Share Posted June 21, 2006 That's the one I was looking for. Thanks! Link to comment Share on other sites More sharing options...
