Ged Trias Posted April 7, 2006 Share Posted April 7, 2006 Anyone have a good way to create parking lot stripes in max from imported autocad lines? Thanks, Ged Link to comment Share on other sites More sharing options...
dnaranjo Posted April 7, 2006 Share Posted April 7, 2006 Hi What I do is, I draw splines using th e auto cad lines as guides. Then I convert the street object into a ShapeMerge object, and merge it to the splines. Then I convert it to an editable poly and select those polygons and apply a standard white material. I hope this is helpful Daniel Naranjo Link to comment Share on other sites More sharing options...
Ged Trias Posted April 7, 2006 Author Share Posted April 7, 2006 Thanks for the reply, I would like to avoid redrawing parking stripes if possible- there are a quite a few stripes and the lot is rather complex. Can't I convert the acad lines directly to splines? Link to comment Share on other sites More sharing options...
STRAT Posted April 7, 2006 Share Posted April 7, 2006 any line in max is a spline. just make it renderable. Link to comment Share on other sites More sharing options...
Chad Warner Posted April 7, 2006 Share Posted April 7, 2006 Make your parking lines polylines in Acad, then give them a width of 6" (or 4"). When you import them into Max, they will come in as closed splines. Then give them an edit mesh or UVW modifier, and they'll be solid. Link to comment Share on other sites More sharing options...
