ZFact Posted April 11, 2006 Share Posted April 11, 2006 I am trying to insert a rendering into a photograph.. The existing photograph has alot of planting in the foreground which I would like to keep in the foreground of the final image. Is there any tips / tricks out there that would make this an easier task and a better job than simply cutting the rendering around the planting? Link to comment Share on other sites More sharing options...
STRAT Posted April 11, 2006 Share Posted April 11, 2006 apply the forground photo to your model as a proxy image. that is, like apply it to a separate plane infront of your model where it would be on a shadow/matte material if its in viz/max, or for example a frontal mapped material in cinema 4d. it should interact nicely into your scene making your post photoshop work a tad easier. Link to comment Share on other sites More sharing options...
ZFact Posted April 11, 2006 Author Share Posted April 11, 2006 Hi Stephen; Im using C4D... the final image will use part of the background of the image and part of the foreground. Do I drop the same photograph into the background scene object and the foreground scene object.. Or do I need to do some pre photshop work to create the foreground image? Does this make sense? Link to comment Share on other sites More sharing options...
IHAB Posted April 12, 2006 Share Posted April 12, 2006 I did this long time ago,I used the background pic at first in max to adjust camera & rendered.Then used the background again in photoshop to place the trees infont of the bridge. PS the background pic is the lake without that bridge. Link to comment Share on other sites More sharing options...
ZFact Posted April 12, 2006 Author Share Posted April 12, 2006 its the cutting the trees out in the foreground to sit infront of the bridge... thats what im having trouble doing. I know you can spend the time and cut around each branch twig and leaf but i am wondering is there any tricks out there to make this process of composition speedier Link to comment Share on other sites More sharing options...
IHAB Posted April 12, 2006 Share Posted April 12, 2006 its not like that, you firstly render the scene with the background,then use the background in photoshop by magicwand+some feather selection & y're done! it is the easiest part m8 Link to comment Share on other sites More sharing options...
ZFact Posted April 12, 2006 Author Share Posted April 12, 2006 Ok thanks anyway for the help Ihab & Stephen; I'll try the olf magic wand and feather tool... Link to comment Share on other sites More sharing options...
