Sketchrender Posted April 13, 2006 Share Posted April 13, 2006 Hi Can somebody please tell me, is there a quick way of changing vray materials to standard max materials. I have to send out a model and they don't have vray, and want all the vray materials changed to standard. Do I have to start al over again. Any help would be great. thank you phil Link to comment Share on other sites More sharing options...
Tim Saunders Posted April 13, 2006 Share Posted April 13, 2006 Unless there is some sort of max script or something, you have to make new materials one at a time as far as I know. One thing that may help is to click and drag mix mats straight into one of the material spaces. This makes it so you don't have to locate the bitmap paths and input the mix amounts etc. Then you can drag that block you just copied into straight into the desired slot on your new material. I usually keep one material block open just for that purpose. While it is not a complete conversion like you're hoping, it does save some time. Link to comment Share on other sites More sharing options...
manta Posted April 13, 2006 Share Posted April 13, 2006 Hey this should work... After you convert them, all the materials in the editor will not be the materials in the scene anymore, you'll notice all the white corners are gone, so you'll have to use the eyedropper or some other method to get the scene materials back into the editor... Link to comment Share on other sites More sharing options...
keeganb_2000 Posted July 4, 2008 Share Posted July 4, 2008 Is there a particular place this should be installed. I couldnt find it in the customize dialog? Link to comment Share on other sites More sharing options...
harumscarum Posted July 9, 2008 Share Posted July 9, 2008 install and you will find it in customize > main ui > 3dzvertools Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 19, 2008 Share Posted August 19, 2008 Trying this out and I'm not sure where to install it. When you run the setup, it says to choose the folder in which to install. Where should it be installed? Link to comment Share on other sites More sharing options...
harumscarum Posted August 20, 2008 Share Posted August 20, 2008 install it to maxroot directory or just use following archive Link to comment Share on other sites More sharing options...
xkj1986 Posted August 25, 2008 Share Posted August 25, 2008 Trying this out and I'm not sure where to install it. When you run the setup, it says to choose the folder in which to install. Where should it be installed? doop Link to comment Share on other sites More sharing options...
Randy liddil Posted November 7, 2008 Share Posted November 7, 2008 I installed it correctly right to the root directory but for some reason it gave me this error. i attached a screenshot Link to comment Share on other sites More sharing options...
Randy liddil Posted November 7, 2008 Share Posted November 7, 2008 nevermind, just figured it out. Thanks so much! This Script is absolutely amazing! Link to comment Share on other sites More sharing options...
bing66 Posted April 6, 2009 Share Posted April 6, 2009 i get this error, but not sure how to solve the problem any help cheers Link to comment Share on other sites More sharing options...
mbaldin Posted August 11, 2009 Share Posted August 11, 2009 Hi, Randy. Would you please tell me how you solve this problem? I've got the same error message everytime I try to use the script. I also don't know if I have to select an object which has the material applied to before I access the script, etc. Regards, Marcos Baldin marcosbaldin@gmail.com Link to comment Share on other sites More sharing options...
KIT Posted August 11, 2009 Share Posted August 11, 2009 Here's another script that does something similar: http://www.scriptspot.com/3ds-max/material-converter-v0-98b Link to comment Share on other sites More sharing options...
mbaldin Posted August 12, 2009 Share Posted August 12, 2009 Wow! Thanks a lot, Marco. Despite I I'll have do do minor adjustments after convertion, this script will save me tons of time. Best regards, Marcos Baldin Link to comment Share on other sites More sharing options...
cjjat puresilica Posted August 15, 2009 Share Posted August 15, 2009 Can anyone please help me overcome the problem I have with the following Maxscript error please. Thank you, Cjj -- Error occurred in GetRenderers(); filename: C:\Program Files\Autodesk\3ds Max 2009\VRayMtlConverter\VRayMtlConverter2.mse; position: 1646 -- Defined in encrypted script -- called in anonymous codeblock -- Defined in encrypted script -- Error occurred during fileIn in >> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2009\VRayMtlConverter\VRayMtlConverter2.mse Exception: -- No "">"" function for undefined Link to comment Share on other sites More sharing options...
shravanminocha Posted August 23, 2009 Share Posted August 23, 2009 Hey, Can you please tell me if this script for converting Vray material to Standard material is also avilable for Max 2010 design with Vray Adv 1.5 SP3 Link to comment Share on other sites More sharing options...
KIT Posted August 23, 2009 Share Posted August 23, 2009 Scripts usually have very little compatibility issues so it's probable it will work. Just try it. Link to comment Share on other sites More sharing options...
shravanminocha Posted August 23, 2009 Share Posted August 23, 2009 I have tried buddy. But it is not working. So that's y i was askin ? Link to comment Share on other sites More sharing options...
KIT Posted August 23, 2009 Share Posted August 23, 2009 That's odd, what script are you trying, and what error did you get? Link to comment Share on other sites More sharing options...
shravanminocha Posted August 23, 2009 Share Posted August 23, 2009 I first installed VRayMtlConverter2_info (given in this post) . Then I went to Run Script and tried to run VRayMtlConverter_v25.mse A tool box should appear... as it says.. but nothing comes up .. Am i doing something wrong anywhere ? Link to comment Share on other sites More sharing options...
KIT Posted August 23, 2009 Share Posted August 23, 2009 I would try the second on (the one I posted) since it's newer. Check the maxscript listener to see if any error shows up in there. Link to comment Share on other sites More sharing options...
pranvera Posted May 4, 2011 Share Posted May 4, 2011 hi i downloaded the script and i have been trying to covert max materials to Vray but im having difficulties in doing it...plz can someone help me with it...thanks ^_^ Link to comment Share on other sites More sharing options...
CliveG Posted May 4, 2011 Share Posted May 4, 2011 I think one of us has got the wrong end of the stick here Pranvera. I'm seeing this thread (and the script) as converting from VRAY mat's to MAX mat's; you're saying you want to convert MAX mat's to VRAY. Which I believe can be done relatively simply with the Vray Scene Converter selected from the quad menu's. I haven't tried the script so could be wrong, I'm just going by reading the thread. Hope this what you were after.... Or have I missed something? Link to comment Share on other sites More sharing options...
infografia3d Posted June 4, 2012 Share Posted June 4, 2012 thanks Any help would be great. thank you phil Link to comment Share on other sites More sharing options...
taido Posted June 10, 2012 Share Posted June 10, 2012 hix.i can't downd load it.help me Link to comment Share on other sites More sharing options...
