spin Posted April 16, 2006 Share Posted April 16, 2006 hi guys... need some tips here.. what map should i use in the environment? when i used vray rendering, the environment seems too dark. i tried hdri maps but its still the same. Link to comment Share on other sites More sharing options...
AJLynn Posted April 17, 2006 Share Posted April 17, 2006 Did you set an environment in the Max Rendering environment and the Vray GI environment? How did you load the HDR? Whatever environment I use, I usually instance it into a material slot and instance it into Vray and Max environments. A gradient ramp can work well for the sky, or an HDR. Evermotion has a set of free HDRs you can download, some of which are good, and I do some of my own with a digital camera and Photoshop, or if you happen to have Maxwell you could get the new-technology-procedural-sky look by setting up a blank scene with the sky you want and using the Photoshop HDR creating procedure on shots taken in it... actually, that's a good idea, I think I'll do that tomorrow and post files. Link to comment Share on other sites More sharing options...
spin Posted April 18, 2006 Author Share Posted April 18, 2006 thanks aj, but i hav tried that option. i got a sky.jpg scene, its a bright scene.. but wen i paced it in the environment using vray, it became dark.. do i need to put an omni or other lights? Link to comment Share on other sites More sharing options...
puciorek Posted May 9, 2006 Share Posted May 9, 2006 Did you set an environment in the Max Rendering environment and the Vray GI environment? How did you load the HDR? Whatever environment I use, I usually instance it into a material slot and instance it into Vray and Max environments. A gradient ramp can work well for the sky, or an HDR. Evermotion has a set of free HDRs you can download, some of which are good, and I do some of my own with a digital camera and Photoshop, or if you happen to have Maxwell you could get the new-technology-procedural-sky look by setting up a blank scene with the sky you want and using the Photoshop HDR creating procedure on shots taken in it... actually, that's a good idea, I think I'll do that tomorrow and post files. Ajllyn, How do you make HDRI using your digital camera? I know the latest Photoshop version supports HDRI but how do you make them? Thanks Link to comment Share on other sites More sharing options...
Logitek Posted May 9, 2006 Share Posted May 9, 2006 thanks aj, but i hav tried that option. i got a sky.jpg scene, its a bright scene.. but wen i paced it in the environment using vray, it became dark.. do i need to put an omni or other lights? I'm gonna ask this since it happened to me... Do you, by any chance, use a cylinder or a sphere with a texture applied on it for your background? Set incorrectly, this stops all rays coming from the HDR environment --> black scene. Link to comment Share on other sites More sharing options...
puciorek Posted May 9, 2006 Share Posted May 9, 2006 I'm gonna ask this since it happened to me... Do you, by any chance, use a cylinder or a sphere with a texture applied on it for your background? Set incorrectly, this stops all rays coming from the HDR environment --> black scene. it happened to me too, how do you fix it? exclude it from GI? Link to comment Share on other sites More sharing options...
Logitek Posted May 11, 2006 Share Posted May 11, 2006 it happened to me too, how do you fix it? exclude it from GI? Well, until I find a better solution, I don't use a background in max and add it in photoshop instead (which I find better to fine tune anyway). Someone has a better way? Link to comment Share on other sites More sharing options...
ApeiNe Posted May 13, 2006 Share Posted May 13, 2006 same one for me Logitek (: Link to comment Share on other sites More sharing options...
Brian Smith Posted May 13, 2006 Share Posted May 13, 2006 If you apply exposure control in the Color Mapping rollout, might want to deselect Affect Background. I recommend using a cylinder with a map as the background. Brian Link to comment Share on other sites More sharing options...
