kajtel Posted April 18, 2006 Share Posted April 18, 2006 http://ignjat.web1000.com/tutorial.html shake fusion Link to comment Share on other sites More sharing options...
Christopher Nichols Posted April 18, 2006 Share Posted April 18, 2006 Interesting... While I don't think the math is accurate, it is interesting to see your work around to the overbright pixels. Newer version of Vray seem to be addressing the sampling problem with those pixels, so there sould be no need to do that any more. But basically what you are doing is clamping your lighting via the diffuse... you may want to try simply clamping your lighting. A lot of the issues you are having may also related to the AA method that you are using. What method are you using? In either case, it is an interesting and clever work around, hopefully new versions of Vray will allow you not to need it. Link to comment Share on other sites More sharing options...
kajtel Posted April 18, 2006 Author Share Posted April 18, 2006 Quote A lot of the issues you are having may also related to the AA method that you are using. What method are you using? adaptive qmc, could you tell why is this related to light`s problems? i will try later with adaptive sub. to see is there any diference. Link to comment Share on other sites More sharing options...
daniel_zevahc Posted April 20, 2006 Share Posted April 20, 2006 How can I save good openEXR with max 7 and vray?, I downloaded the Splutterfish plugin but there are so many options in the setup options than my head hurts. I just downloaded Combustion demo to experiment myself with compositing, and I want to be sure that my files are in good shape, if so, can I also use RPF instead? Link to comment Share on other sites More sharing options...
kajtel Posted April 20, 2006 Author Share Posted April 20, 2006 i use this setings Link to comment Share on other sites More sharing options...
kajtel Posted May 17, 2006 Author Share Posted May 17, 2006 I made some update of tutorial for AE and Shake Link to comment Share on other sites More sharing options...
daniel_zevahc Posted May 18, 2006 Share Posted May 18, 2006 Great, but your page seems to be down. Link to comment Share on other sites More sharing options...
kajtel Posted May 18, 2006 Author Share Posted May 18, 2006 http://ignjat.web1000.com/tutorial.html i it is not down for me serbian board where you can see some of tut. http://www.dizajnzona.com/forums/index.php?showtopic=10096&st=80 Link to comment Share on other sites More sharing options...
