ARCHY Posted April 20, 2006 Share Posted April 20, 2006 Hi All Does anyone know how to render wire frame with Vray materials, as It only works when i use mental ray, and vray seems not to recognize this feature, any help would be greatly appreicated. cheers Link to comment Share on other sites More sharing options...
JamesTaylor Posted April 20, 2006 Share Posted April 20, 2006 you need to use the vray edgetex material, its let you choose the colour of the lines and the solid elements too, you can make the solids transparent if you don't want hidden line style Link to comment Share on other sites More sharing options...
MegaPixel Posted April 20, 2006 Share Posted April 20, 2006 Anyone else here missing some Vray materials? I recently purchased Vray 1.47 Advanced and only have 3 Vray materials to choose from - no edgetex, etc... Link to comment Share on other sites More sharing options...
notamondayfan Posted April 20, 2006 Share Posted April 20, 2006 i use this hidden wire plugin. u dont have to assign materials to your objs this way. i have never been able to install the plug in "properly" but i have managed to make it work by assign the plugin to an unused key. hope this helps Link to comment Share on other sites More sharing options...
ARCHY Posted April 20, 2006 Author Share Posted April 20, 2006 Were do you put this file, and how are you using it??? thanks in advance. Cheers Link to comment Share on other sites More sharing options...
notamondayfan Posted April 20, 2006 Share Posted April 20, 2006 copy the .ms file into your scripts folder of max. (doesnt really matter where, but best to put them some where sensible) then inside max, click UTILITIES, MAXSCRIPT, RUN SCRIPT then find the .ms file. it should self install if i remember correctly. then the way i got it to run is to goto CUSTOMISE, CUSTOMISE USER INTERFACE. then under cattogry select ALL COMMANDS then scroll down to HIDDEN WIREFRAME RENDER and assign it to a key you dont use. was a while bk since i installed it, but i think thats how i did it. Link to comment Share on other sites More sharing options...
WaseemOnLiNe Posted January 14, 2009 Share Posted January 14, 2009 Hi, I just find this post, and download the file, and insert it inside max, and everything goes all right, but it doesnt work like a frame work. Link to comment Share on other sites More sharing options...
Donor Posted January 21, 2009 Share Posted January 21, 2009 What about using the VrayToon effect? http://www.spot3d.com/vray/help/150R1/vraytoon_params.htm Link to comment Share on other sites More sharing options...
