John Martin Posted April 21, 2006 Share Posted April 21, 2006 Just a quick question. I have an arched object in Max (imported from ADT 2004) that I need to apply a brick soldier course texture map to. How do I apply the map and have it follow the curve of the object and not just map straight ahead? Link to comment Share on other sites More sharing options...
Quique Posted April 21, 2006 Share Posted April 21, 2006 I would suggest recreating the arch using a loft object. When you repeat tiling in a loft object, the tiles follow the path. Link to comment Share on other sites More sharing options...
DennisHolland Posted April 21, 2006 Share Posted April 21, 2006 Yes it does, but then you got to be carefull and prepare your map before applying it to your object. The loft technique is correct, but only if NOT uv mapped afterwards. Calculate your brick amount and adjust your brick texture in Photoshop before start.... Regards. Post your stuff when finished? Dennis Link to comment Share on other sites More sharing options...
theqball Posted April 22, 2006 Share Posted April 22, 2006 Hi john, you are going to want to read up on "unwrap uvw". Link to comment Share on other sites More sharing options...
ZFact Posted April 23, 2006 Share Posted April 23, 2006 When doing soldier courses on an arch i always find it alot easier and less time consuming to actually model each brick and mortar joint. They can be modelled in minutes and if they are repeated over the facade use instances to duplicate them. That should save you alot of photoshop and mapping time Link to comment Share on other sites More sharing options...
markf Posted April 24, 2006 Share Posted April 24, 2006 I have often assigned the soldier course map to a box created with multiple segments. Add the UV map. Add Bend modifier. You may need to mess around with which veiwport you create the box in and which axis you use the Bend on, but this has worked well for me. hope this helps Link to comment Share on other sites More sharing options...
theqball Posted April 26, 2006 Share Posted April 26, 2006 It always amazes me what everyone goes through to not learn Unwrap UVW. This is really a simple 1 minute (maximum) task in unwrap, it's just a different way of thinking about texturing. I really need to get on the ball and write a tutorial for this one of these days.... Link to comment Share on other sites More sharing options...
philix Posted April 27, 2006 Share Posted April 27, 2006 while auto-learning maxscript i have made an "arch generator" (just for fun ) it uses a torus to make the arch, so it's automatically mapped i'm sorry but the interface is in italian and i have not the time to translate, maybe in the future here's the script: http://www.treddi.com/upload/philix/MaxScript/GeneratoreArchi004.ms here's a little movie that shows the script in action (techsmith codec): http://www.treddi.com/upload/philix/VideoTutorials/MaxScript_GeneratoreArco.avi PS i'm agree with thegball, the best solution is the unwrap UVW Link to comment Share on other sites More sharing options...
notamondayfan Posted April 27, 2006 Share Posted April 27, 2006 nice script, but i agree unwrap uvw is soooo useful.i usually end up using it when im creating roads, car parks, or even skinning characters and things like that. Link to comment Share on other sites More sharing options...
ZFact Posted April 27, 2006 Share Posted April 27, 2006 It always amazes me what everyone goes through to not learn Unwrap UVW. This is really a simple 1 minute (maximum) task in unwrap, it's just a different way of thinking about texturing. I really need to get on the ball and write a tutorial for this one of these days.... I would greatly appreciate it if you could write a wee tutorial on this subject as it is something i always struggle with Link to comment Share on other sites More sharing options...
