jophus14 Posted April 24, 2006 Share Posted April 24, 2006 Will I be able to open and modify files from either Max7 to Viz2006 or vise-versa. I'm using Viz2006 at work and Max 8 at home and the files won't open in Viz2006 if I modify and resave in Max8, but will Viz2006 files open in Max 7 if I downgrade? Link to comment Share on other sites More sharing options...
Chad Warner Posted April 24, 2006 Share Posted April 24, 2006 Viz 2006 files will open in Max 7 no problem. Max 7 files will open in Viz 2006 as long as there are no modifiers that are only in Max applied to the objects. You'll know it if there are becuase Viz will give you missing DLL errors. Link to comment Share on other sites More sharing options...
jophus14 Posted April 24, 2006 Author Share Posted April 24, 2006 Thank you, i guess it's time to downgrade my Max then What about if I have Vray 1.47 at home and version 1.46 at work will they work together when switching back and forth in between programs? Link to comment Share on other sites More sharing options...
