mikacool Posted April 26, 2006 Share Posted April 26, 2006 HELLO AGAIN THIS TIME IS FOR The Moire effect SOMEBODY KNOWS LIKE SOLVING THIS. MOIRE OR mouare I DONT KNOW THE RIGTH NAME THE ONE OF THE DESK I AM SOLVING IT Link to comment Share on other sites More sharing options...
edub Posted April 27, 2006 Share Posted April 27, 2006 I'd check the AA settings, as this seems to be a geometry issue. Usually moire happens with texture maps, and can be lessened with higher AA, as well as various map settings (MIP, SAT, etc). In this case looks like a simple case of "increase your AA settings". Link to comment Share on other sites More sharing options...
mahorela Posted April 27, 2006 Share Posted April 27, 2006 Solving the Moire or scintillation can sometimes be as simple as lessening your threshold in your AA settings. Choose adaptive subdivision and take it down to .05 or so. Will increase render times but stop that annoying scintillation and Moire. Link to comment Share on other sites More sharing options...
Zeilveen Posted April 27, 2006 Share Posted April 27, 2006 Had the same problem with my wooden shutters! I didnt know there was a name for this. I changed the subdiv settings (about doubled it) and used higher antialiasing settings. Took forever to render btw. Link to comment Share on other sites More sharing options...
STRAT Posted April 27, 2006 Share Posted April 27, 2006 yup, purely donw to aa settings/filters in whatever 3d renderer you use. and yup, fine tuning the aa will certainly slow it down, but on the plus side, you should be able to localise the high aa settings to just the parts that need it. Link to comment Share on other sites More sharing options...
Zeilveen Posted April 27, 2006 Share Posted April 27, 2006 "you should be able to localise the high aa settings to just the parts that need it." This is new to me, what could that mean? Is there an object property called AA or something? Could safe hours of rendering time.. thanks Ronald plz, dont mean to change the subject, but was very curious.. Link to comment Share on other sites More sharing options...
STRAT Posted April 27, 2006 Share Posted April 27, 2006 it means most (or allot anyway) 3d applications allow you to individually adjust individual objectses properties. like if the blinds aren't rendering smooth enough i can up the aa properties on the blinds only. Link to comment Share on other sites More sharing options...
mikacool Posted April 27, 2006 Author Share Posted April 27, 2006 here they are the parameters that I have, sorry but i dont know which is the aa seeting they could indicate to me please. Link to comment Share on other sites More sharing options...
signet Posted April 27, 2006 Share Posted April 27, 2006 a minor moire caused by low settings that is just the result of you using fixed rate antialiasing at a 1 (very low, great for test renders bad for final render) for this i recommend turning on adaptive subdivision with the settings changed from -1 to 1 and leaving the max rate on 2 and bang you should have it looking good. It would moire in the final render if you had more slats in the blinds but as far as i can tell you have a good amount and should not have to worry. Mike Senior designer http://www.uniform.net Link to comment Share on other sites More sharing options...
mikacool Posted April 27, 2006 Author Share Posted April 27, 2006 WAO JEJEE THANKS THANK YOU VERY MUCH ARE SEEN VERY WELL Link to comment Share on other sites More sharing options...
