Zeilveen Posted April 27, 2006 Share Posted April 27, 2006 Well, im pretty new to vray rendering and trying as hard as I can to make a really cool panorama walk around. I will post the result when this is finished, but what is going on with the roof and the roof shadow on the left?? I see some flash of light, which appears to be only here in this frame and not the one next to it. Also the roof is showing some strange dark patterns? Please any tips and C&C are really helpfull. Ronald Link to comment Share on other sites More sharing options...
DennisHolland Posted April 27, 2006 Share Posted April 27, 2006 What mode are you using during calculation of the irradiancemap, Zeilveen? This splotches/flashes, and lot's of other annoyances, mostly occure when you've calculated a single frame map while the best mode is to calculate incrementals over a certain amount of frames along the cam-path... Regards. Dennis Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted April 27, 2006 Share Posted April 27, 2006 do what dennis said. i think you are calculating in bucket mode right now. i see several buckets in the image. Link to comment Share on other sites More sharing options...
Zeilveen Posted April 27, 2006 Author Share Posted April 27, 2006 Thanks Guys, Yep, you are right, its buckets for the squar shadow bits. Too much time went into little things and tuning and forgot to change this one. Rendering one frame with AR map gives an ok image, this one is also showing way too much shadows. I will try incrementals tonight and see what happens with it. Much appreciated thanks, Ronald Link to comment Share on other sites More sharing options...
