chow choppe Posted April 29, 2006 Share Posted April 29, 2006 hi everyone i upgraded my system to AMD x 2 4200 + 939 pin socket 6600gt XFX card A8N32 SLi deluxe board... Now the problem is that i am having problem installing autocad 2007 on that.i tried installing it it gave me error of .net framework. i then installed .net framework from microsoft for 64 bit and it solved the error. now its not givng me that error on launching the setup but when i double click on setup the setup wizard just disappears off the screen and nothing happens after that.... but earlier autocad 2007 installed really easy on my older 32 bit system Please help me with this Thanks Link to comment Share on other sites More sharing options...
chow choppe Posted April 30, 2006 Author Share Posted April 30, 2006 actually the problem is that when i open the cd there is an icon called "media brwser" which generally shows the installation options....its a little transparent greenish box...this box doesn't open on double clicking and there is a setup icon also in the root directory of CD...it also doesn't open on double clickig....BUt if go to \Bin\acadFeui/setup.exe , then the setup runs fine and i am able to install it.... So whats the problem...why my media interface doesn't start....Does it run with the help of a flash player..... Thanks Link to comment Share on other sites More sharing options...
chow choppe Posted April 30, 2006 Author Share Posted April 30, 2006 i figured it out...... My demoshield version is not right as per 64 bit windows. Where can i fix this problem Thanks Link to comment Share on other sites More sharing options...
