chow choppe Posted April 29, 2006 Share Posted April 29, 2006 hi all i am not able to install mcafee on my new AMD z 64 4200+, 939pin socket with 64 bit windows xp.... i just hope i haven't created trouble for myself by getting a 64 bit windows... can i install a 32 bit windows on this new machine What the solution to this problem Thanks Link to comment Share on other sites More sharing options...
mtutaj Posted April 29, 2006 Share Posted April 29, 2006 Yes, you can install 32bit xp on it. That is what I have on all my Amd64 X2 machaines. Link to comment Share on other sites More sharing options...
hotrod Posted April 30, 2006 Share Posted April 30, 2006 3dsmaxed said: hi all i am not able to install mcafee on my new AMD z 64 4200+, 939pin socket with 64 bit windows xp.... i just hope i haven't created trouble for myself by getting a 64 bit windows... can i install a 32 bit windows on this new machine What the solution to this problem Thanks Hi, u can try http://www.avast.com for 64 bit viruscan Link to comment Share on other sites More sharing options...
chow choppe Posted April 30, 2006 Author Share Posted April 30, 2006 thanks for the replies can anyone tell me how to install win xp 32 bit. actually i have SATA1 on my system ...so when this vendor of mine installed xp 64 on my system he did something by inserting a floopy drive and copying the drivers on it i have a winxp sp 2 bootable CD ..in my older machine i just used to run the CD and it used to install on its own,,,,can i use the same procedure while installing in my new machine or will it be a different method Thanks haneet Link to comment Share on other sites More sharing options...
mtutaj Posted April 30, 2006 Share Posted April 30, 2006 it should install the same way. the only reason you would need the driver disk, is if windows doesn't find your SATA drive when it tries to install. Then you would press F- watch the bottom of the screen when windows is installing. you can press the appropriate f- key and then you read the driver disk for your SATA drive. Then all should be good to go. Mike Link to comment Share on other sites More sharing options...
chow choppe Posted April 30, 2006 Author Share Posted April 30, 2006 ok thanks One more question....will my 32 bit overwrite this 64 bit installation. If not then how should i go about uninstalling it or formatting my c drive, because i don't want two operating systems simultaneously. thanks Link to comment Share on other sites More sharing options...
