Another Vray Glass Question
kwerch
Am trying to get some shadows through some vray glass but something is up that I can't catch. for the pane I am using a poly at .25" and applied the vray material to it. Light does pass through but it seems like not enough to create shadows-
The inside image shows the shadowless result, the exterior is showing that I am getting shadows from the light and it is pumping out enough that it should make some difference.
I'll check out the materials link later in the previous post-until then...
thx,
karl
Make sure you have Affect Shadows turned on in you vray glass material.
Its a button under the fog settings. Hope this helps.
thx for info-
I loaded a ready made glass tex material that I downloaded from ?evermotion I think?
The shadows worked fine with this mat. I have not had time yet to see why my set up didn't work and to verify your suggestion- My demo expired that night -
I ordered a version today. I'll give it a check when I get it going again.
thx.
k
