IHAB Posted May 1, 2006 Share Posted May 1, 2006 I wonder if anybody can help me ,I have a PC at home & a LT directly connected to each other,so I just want to render a max scene with a 6cams video post in network vrayrender.does it make sense? If someone can help please in details as network setting stuff is a "godlbedegook" to me thanks! Link to comment Share on other sites More sharing options...
thomas+son Posted May 1, 2006 Share Posted May 1, 2006 http://www.extremetech.com/article2/0,1697,1847365,00.asp set up your own render farm by ExtremeTECH Link to comment Share on other sites More sharing options...
anvaraziz Posted May 1, 2006 Share Posted May 1, 2006 u need to use backburner for network rendering,, go with max help file to setup backburner,,, its all there,,, remember , u should use mapped drives to acces textures and files.. Link to comment Share on other sites More sharing options...
anvaraziz Posted May 2, 2006 Share Posted May 2, 2006 http://www.3dv.com/images/down_on_the_farm.pdf read that,,, Link to comment Share on other sites More sharing options...
IHAB Posted May 2, 2006 Author Share Posted May 2, 2006 oh! gentelmen, I said I only wanted to render with two computers!! someone tell me what to do (1,2,3.......) not all this!! why should I use bakburner? I think it uses a computer as a maneger to the process & I only have two (home pc & a laptop) but thanks alot thomas+son ,anvaraziz Link to comment Share on other sites More sharing options...
anvaraziz Posted May 2, 2006 Share Posted May 2, 2006 no matter 1 or 50 ,, the process of network rendering is same,,,, u should use backburner, couse thats the free one comming with 3dmax, or u can go for highend render q softs,,,, if ur using vray u can do DR in vray,, even for DR u should setup ur drives mapped and all..... there is no other way like plug and render,,, hi hi Link to comment Share on other sites More sharing options...
anvaraziz Posted May 2, 2006 Share Posted May 2, 2006 mods pls fix it , just send reply and it cames as 4 posts... Link to comment Share on other sites More sharing options...
IHAB Posted May 2, 2006 Author Share Posted May 2, 2006 if ur using vray u can do DR in vray,, even for DR u should setup ur drives mapped and all..... there is no other way like plug and render,,, hi hi can you explain this anvaraziz?yes, I am using vray Link to comment Share on other sites More sharing options...
anvaraziz Posted May 2, 2006 Share Posted May 2, 2006 link best luck... Link to comment Share on other sites More sharing options...
sonpts1 Posted May 2, 2006 Share Posted May 2, 2006 I wonder if anybody can help me ,I have a PC at home & a LT directly connected to each other,so I just want to render a max scene with a 6cams video post in network vrayrender.does it make sense? If someone can help please in details as network setting stuff is a "godlbedegook" to me thanks! You must use VRAY only: 1. Go to Vray-Settings\System: check Distributed Rendering 2. Click Settings... then click Add Server: Enter your Computername (Hostname or IP-Address) then click Resolve Servers 3. Go to your 2nd. Computer. In Max folder, run the file: vrayspawner60.exe Make sure that you have installed the same Plugins in both of computers. Do so for the next if you have more 4. Render your scene. sonpts1 Link to comment Share on other sites More sharing options...
IHAB Posted May 2, 2006 Author Share Posted May 2, 2006 thanks guys! thats what I was talking about Link to comment Share on other sites More sharing options...
alfienoakes Posted May 8, 2006 Share Posted May 8, 2006 Just be aware that that is Distributed Rendering.. not Network Rendering.. One does a single frame over the network, the other renders Multiple frames over the network.. they are different things.. Andy Link to comment Share on other sites More sharing options...
