asifsiddiqui Posted May 2, 2006 Share Posted May 2, 2006 Hi Community, Am currently working on this visualization. Requesting for your comments and suggestions. Regards, Link to comment Share on other sites More sharing options...
mahorela Posted May 4, 2006 Share Posted May 4, 2006 what software are you using? looks like max. I have a lot to say about this as long as your using max, at this stage I will say that the lighting needs work, the tiles on the balcony are completely washed out and it's not very well lit as a whole. Your textures could also use some work, the roughness of the tar is far too large and needs to be tiled some more. But I think you need to work on the light before you do anything. please reply and let me know if you are using max and if you are using the scanline renderer as I suspect. I will give you a few tips for getting good results with scanline and no GI. Link to comment Share on other sites More sharing options...
asifsiddiqui Posted May 4, 2006 Author Share Posted May 4, 2006 Thanks a lot mahorela for your kind feedback. Am obliged. As you have guessed, am using Max but rendering is done using Brazil r/s. Will be grateful for your tips. Thanks Link to comment Share on other sites More sharing options...
alikashan Posted May 4, 2006 Share Posted May 4, 2006 aoa nice image man. but i think you need to improve on camera angles along with your texture mapping specially the road texture is blasted and image look too bright shadow lines are very sharp i dont know much about brazil but try to use area shadows or try to soften your shadows man any ways keep it up and also nice site. take ca Link to comment Share on other sites More sharing options...
