jophus14 Posted May 2, 2006 Share Posted May 2, 2006 I am rendering an image at 800X600 like always, then I plan on using the saved prepasses to render out the same image at 3600X2400. I've done it before with other images. For some reason, after loading the saved prepasses, the image wants to go through 3 more prepasses after it just did 4 calculations before it'll begin to render. Why is this happening? Link to comment Share on other sites More sharing options...
Ismael Posted May 3, 2006 Share Posted May 3, 2006 You probably have interpolated glossy on one or more materials. Ismael Link to comment Share on other sites More sharing options...
anvaraziz Posted May 3, 2006 Share Posted May 3, 2006 which version of vray,,,,? Link to comment Share on other sites More sharing options...
jophus14 Posted May 3, 2006 Author Share Posted May 3, 2006 Im using Viz 2006 so I have to use Vray 1.46.15 Link to comment Share on other sites More sharing options...
anvaraziz Posted May 3, 2006 Share Posted May 3, 2006 do u have any interpolation ticked material... chek it... Link to comment Share on other sites More sharing options...
jophus14 Posted May 3, 2006 Author Share Posted May 3, 2006 I'm using some glass that has interpolations, but they are standard Vray glass materials, nothing special. I also have some materials with a falloff as a reflect, but only at 10%-20%, nothing drastic Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 3, 2006 Share Posted May 3, 2006 The interpolation that is done on your material is done on the pre-pass. Reflection and refraction cannot be baked in so they have to be calculated no matter what on every frame. That is the bad news. The good news is that the pre-pass will only be used to calculate your glossy effect so the pre-pass will go a lot quicker then it normally does for the diffuse lighting, plus in the end, it will save you a lot of time off the final rendering. Link to comment Share on other sites More sharing options...
jophus14 Posted May 3, 2006 Author Share Posted May 3, 2006 Thanks for the explanation Christopher. The second set of prepasses are quite quick. I love the Interior/Exterior DVDs by the way. Link to comment Share on other sites More sharing options...
