heeeelllllpppp plsss!!!!
hi all... why do i get this message?..."out of memory" !!! :( it will appear after the last rendering is done...im just using scanline here...do you have any idea on how to fix this......i am using double cpu xeon intel 3.20 ghz ,2.80 ghz....with 2.00 of ram...but i still ran out of memory....hope you can help me....tnx in advance!!!:)
Are those RPC's in your scene..?
If so, turn them off, and then try and re-render. If it does, then they are either causing, or not helping the problem.
Once you get a load of them in a complex scene, they can give you out of memory errors..
try it, and see if it works..
Andy
this error massege often comes out when there is a ram problem,cause the hard drive is used by virtual memo & thus isnt capable of saving output image>Im afraid you have the lo ram problem!
the only solution in this case is adding more ram
