landrvr1 Posted May 4, 2006 Share Posted May 4, 2006 I'm rendering out several .tif images for an objectVR, but I need the numbering to start at 0001 instead of 0000. Does anyone know how to do this; or if it can even be done? Thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted May 4, 2006 Share Posted May 4, 2006 you mean to get max to start @ frame1? or just start numbering with one? either way whatever it turns out you could use a mass file re-naming utility like Siliwin. Link to comment Share on other sites More sharing options...
Trick Posted May 4, 2006 Share Posted May 4, 2006 You could skip Windows Explorer and start using Directory Opus. It's far more powerful on File and Folder operations and has it's own scripting for more advanced operations. I can't live without it anymore... Link to comment Share on other sites More sharing options...
landrvr1 Posted May 5, 2006 Author Share Posted May 5, 2006 Thanks alot guys. Didn't even think about a file renaming utility. Siliwin works perfectly to rename the first file as 0001 and then increase from there. Going to check out Directory Opus -which seems like a great program. Link to comment Share on other sites More sharing options...
3dfreelancer Posted May 5, 2006 Share Posted May 5, 2006 Hi Scott You can just set up Max the way you want in the time configuration (the icon with the watch in the timeline), just set the start to either 0 or 1 and render "active segment". Kind regards Michael Link to comment Share on other sites More sharing options...
