BrianKitts Posted May 5, 2006 Share Posted May 5, 2006 working on an update to a current project.... any suggestions? - thx!!! Link to comment Share on other sites More sharing options...
antonio_frias Posted May 5, 2006 Share Posted May 5, 2006 That looks great Brian! What program did you use to model your trees? Your grass looks very realistic, did you use a displacement map for it? Link to comment Share on other sites More sharing options...
BrianKitts Posted May 5, 2006 Author Share Posted May 5, 2006 yes displacement grass w/ onyx trees (palms) Link to comment Share on other sites More sharing options...
Tim Saunders Posted May 5, 2006 Share Posted May 5, 2006 Looks really nice. Your current camera angle boasts the landscape more thant the building, but maybe that's your purpose. Or maybe your just hoping to have a more artistic peice. Looks good either way. the wall texture does look a bit plain and flat. Link to comment Share on other sites More sharing options...
BrianKitts Posted May 5, 2006 Author Share Posted May 5, 2006 actually you kinda nailed it Tim.... this image was more to show the client the coverage the royal palms provided.... but you're right I did slack on the wall material.... should hit that one better. Link to comment Share on other sites More sharing options...
skala67 Posted May 5, 2006 Share Posted May 5, 2006 Im sure this has been covered elsewhere, but did you use a displacement map for the grass? If so can you post it? thanks, Link to comment Share on other sites More sharing options...
BrianKitts Posted May 5, 2006 Author Share Posted May 5, 2006 check out the tutorials section @ evermotion.... it will give you the mats, and describe how to use them... I've customized the material a little bit, but you can get really good results directly off of evermotions site. Link to comment Share on other sites More sharing options...
