ahmed mansy Posted May 5, 2006 Share Posted May 5, 2006 hi guys how would i get a realistic light for exteriors with vray??.Should i use HDRI or only normal lights?? .I hope u can help me with that. thanks Link to comment Share on other sites More sharing options...
Jeffrey Posted May 5, 2006 Share Posted May 5, 2006 I use HDRI most of the time and it turn out quite good. Link to comment Share on other sites More sharing options...
antonio_frias Posted May 5, 2006 Share Posted May 5, 2006 HDRI, no doubt about it Link to comment Share on other sites More sharing options...
ahmed mansy Posted May 5, 2006 Author Share Posted May 5, 2006 do u have any tutorial about using HDRI Link to comment Share on other sites More sharing options...
antonio_frias Posted May 5, 2006 Share Posted May 5, 2006 Gnomon Global Illumination Exteriors DVD http://www.thegnomonworkshop.com/dvds/cni01.html Link to comment Share on other sites More sharing options...
ApeiNe Posted May 8, 2006 Share Posted May 8, 2006 HDRI is great sure, but not so fast to render >:/ U can tweak it using a projector map, will be pretty more faster Link to comment Share on other sites More sharing options...
puciorek Posted May 9, 2006 Share Posted May 9, 2006 HDRI is great sure, but not so fast to render >:/ U can tweak it using a projector map, will be pretty more faster Will you get the same resoults? Link to comment Share on other sites More sharing options...
ApeiNe Posted May 10, 2006 Share Posted May 10, 2006 yep, the result still be good. The control is not so goos as an Hdri sepcialy for animation... But for a Fixe shot, that could really be engouh and pretty more fast. U can also use a LowDef HDRI on the sky slot. Just edit your reflexion map with HDRShop and reduce and blur it, to get faster renders. for exemple : Default HDR image size 1024*1024 Reduce HDR image size 256*256 Hope that could help.... All the best ApeiNe Link to comment Share on other sites More sharing options...
