aligrafix Posted May 6, 2006 Share Posted May 6, 2006 thanks for those who are viewing and answering here is problem: i have particle systems in my 3dsmax. i want to apply blur to them individually. while using the scanline renderer, we can apply blur on individual objects by accessing their properties, my question is that, that blur with properties cant be rendered in vray. Can i apply blur using vray, either it is accessable from vray properties of the object? or what is the way to do it? i dont know about it and stuck. please! help me Regards Link to comment Share on other sites More sharing options...
BunGHoLe Posted May 6, 2006 Share Posted May 6, 2006 You can find a motion blur under Vray::Camera roll out but I'm not really sure if this is what you want.... Link to comment Share on other sites More sharing options...
aligrafix Posted May 7, 2006 Author Share Posted May 7, 2006 BunGHoLe said: You can find a motion blur under Vray::Camera roll out but I'm not really sure if this is what you want.... thanks for replying but i really know the camera blur under vray--> camera rollout. it actually works for me for animated camera. but let me give you an example. if i have f-16 flying, lauches a missle, then i need to create a smoke of that missle with particles systems. simply particles not give me the real smoke effect until i apply blur on that. so i need to apply blur on particles of the smoke. i think now you got me. waiting for help again regards Link to comment Share on other sites More sharing options...
BunGHoLe Posted May 7, 2006 Share Posted May 7, 2006 Yep...I thought this won't work. The other thing I can think of is to use video post. Render the smoke with scanline and for the rest use Vray. Link to comment Share on other sites More sharing options...
aligrafix Posted May 8, 2006 Author Share Posted May 8, 2006 BunGHoLe said: Yep...I thought this won't work. The other thing I can think of is to use video post. Render the smoke with scanline and for the rest use Vray. i got it. i tried that but i have to composite it in other software. i dont want that. i dont know why vray doesnt have the object blur parameters and if it has then where are they. i have checked all of settings but they are not there. i want to render it using vray. Anyother guy knows about it?? shall be thankful for this help! Link to comment Share on other sites More sharing options...
3dsandy Posted May 11, 2006 Share Posted May 11, 2006 hi...im a new user... pls help me ... how do i upload my work on cgarchitects. Secondly i would like to knw how can i render to texture in Vray. i also want to make light comin thru teh glass windows and casting sadows inside Link to comment Share on other sites More sharing options...
ApeiNe Posted May 13, 2006 Share Posted May 13, 2006 aligrafix, try to active the Vray frame Buffer, then Render Element panel, and choose the things U want... And after u can just edit that under PS Link to comment Share on other sites More sharing options...
aligrafix Posted May 14, 2006 Author Share Posted May 14, 2006 APiene Do you mean, "texture baking"? Link to comment Share on other sites More sharing options...
ApeiNe Posted May 14, 2006 Share Posted May 14, 2006 nop (: Just render a seperate layer with object id or anything can give you your particles. Just go in the "Vray::Framme buffer" panel and enable it Go it the "Render Element" tab, "Add.." and add the layers you want. After the render, go into Photoshop and open the render and the layer. Now, to apply a blur on the particles, U just have to select it easily with the layer, and apply the blur on the render. Here some screenshot to explain it better ^^ Link to comment Share on other sites More sharing options...
aligrafix Posted May 15, 2006 Author Share Posted May 15, 2006 thanks for your help dear. i shall try that i see what i get now. thank you Link to comment Share on other sites More sharing options...
