justintime1 Posted May 8, 2006 Share Posted May 8, 2006 Hi there folks, Right this is probably a stupidly simple thing to achieve but I cant fathom how to do it. Is it possible to line a spline between two pints that have different Y values and yet allow the spline to keep its various x and z values . In the image show A and B have different Y values due to an uneven site. The points in-between need to be lined up in a smooth curve . Short of manually moving every point I cant fathom out how to do it. Id assume that there was a tool but cant seam to find one that will do what I want it to . All suggestions are very welcome. Link to comment Share on other sites More sharing options...
leed Posted May 8, 2006 Share Posted May 8, 2006 Is this what you mean? If you select the points you get given the x. y. z. dimentions of the points in the Coordinate manager. if you want them to line up between A and B first rotate the origin to line up with the points then put the x value to 0. Link to comment Share on other sites More sharing options...
justintime1 Posted May 8, 2006 Author Share Posted May 8, 2006 Hey there lee. Cheers for the suggestion, it has helped out but im still not entirely happy with the outcome. Im not so sure im going about int in the best way. Iv had to make do however as the deadling is creeping up way to fast. Thank you very much for you help. Matt. Link to comment Share on other sites More sharing options...
