hrvojezg00 Posted May 8, 2006 Share Posted May 8, 2006 I`m buying 2x265 opteron, that means 4x1.8 ghz.I have a question: when I setup a scene for rendering, press render do all 4 cores work together, with 7.2 ghz? Link to comment Share on other sites More sharing options...
Devin Johnston Posted May 9, 2006 Share Posted May 9, 2006 This depends on the software you’re using, if your software is multithreaded then yes it will use all cores. If you’re using something like ArchiCAD then no because it's not multithreaded and can't use more than one core. Link to comment Share on other sites More sharing options...
IHAB Posted May 10, 2006 Share Posted May 10, 2006 I`m buying 2x265 opteron, that means 4x1.8 ghz.I have a question: when I setup a scene for rendering, press render do all 4 cores work together, with 7.2 ghz? Its not like that m8 ! read this thread: http://www.cgarchitect.com/vb/16546-dualcorecentrino1-6ghz-faster-than-dualcore-3ghz.html Link to comment Share on other sites More sharing options...
