emortal Posted May 9, 2006 Share Posted May 9, 2006 I've just installed Architectural Materials plugin into my 3ds max 7 but when i go to select an arch materials all of the samples are not there & are relaced with just black spheres. can any1 help please??? Link to comment Share on other sites More sharing options...
Kibble Posted May 9, 2006 Share Posted May 9, 2006 have you checked to see if the textures are in the archmat file? in max\\maps\ArchMat Link to comment Share on other sites More sharing options...
emortal Posted May 9, 2006 Author Share Posted May 9, 2006 yes i think they are but i'm not at my home computer at the moment. have you any suggestions to resolve this problem if there materials are there or if they are there? Link to comment Share on other sites More sharing options...
notamondayfan Posted May 9, 2006 Share Posted May 9, 2006 do u mean the samples are appearing black in the material editor? if so, unclick the Backlight button (2nd one down on the right of the mat editor) Link to comment Share on other sites More sharing options...
nisus Posted May 11, 2006 Share Posted May 11, 2006 Hi I don't know what renderer you use, but if you use MR DO NOT use the arch.materials. It's searching prob! ,-) rgds, nisus Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted May 11, 2006 Share Posted May 11, 2006 Same with VRay. Link to comment Share on other sites More sharing options...
nisus Posted May 11, 2006 Share Posted May 11, 2006 looooooooooooooooooooooool... bascily: the idea is good, you do not need to know materials to get good looking stuff... BUT it does not work that way... they are HARD to tweak and generate A LOT of artifacts... so no go! nisus Link to comment Share on other sites More sharing options...
abicalho Posted May 16, 2006 Share Posted May 16, 2006 Which architectural materials are you talking about? MAX 7 comes with Architectural Materials out of the box, there's no need to install any plugin. Mental Ray and Scanline support them entirely without problems. Link to comment Share on other sites More sharing options...
nisus Posted May 16, 2006 Share Posted May 16, 2006 Hi Alex, Yes the ones out of 7 I meant. I found them hard to tweak: wood did not look like wood, nor did the ceramics or stones, plaster... Hard to tweak the speculars, because they are bound with the refraction index... And there was the black dot issue!! But than again, I also changed my lighting setup completely after using them, so maybe now they would work... Do yo uuse them a lot? Do you have a sample with them? rgds, nisus Link to comment Share on other sites More sharing options...
