edub Posted May 10, 2006 Share Posted May 10, 2006 my first WIP post - let me have it I'm pretty happy with it, but have been messing with it for so long that I might be missing something. Any C/C are welcomed. Modeled/rendered in C4D. Link to comment Share on other sites More sharing options...
ctk111 Posted May 10, 2006 Share Posted May 10, 2006 Nice rendering. My only comment would be that the image out the window appears too bright. The outside image lighting doesn't seem to match the interior lighting. Otherwise, it looks good. Link to comment Share on other sites More sharing options...
mahorela Posted May 11, 2006 Share Posted May 11, 2006 i like it although I agree about the background, are we seeing it through a window? some reflection off the glass would be good so as to represent a window rather than an odd shaped hole in the wall. Link to comment Share on other sites More sharing options...
edub Posted May 12, 2006 Author Share Posted May 12, 2006 I messed around with it a little - changed the view angle a bit, added some grass elements. Link to comment Share on other sites More sharing options...
Sawyer Posted May 12, 2006 Share Posted May 12, 2006 No don't cut off the tub! Link to comment Share on other sites More sharing options...
Zeilveen Posted May 13, 2006 Share Posted May 13, 2006 Yep, dont cut the topic out of your image, low camera works better with that, first image has it all. The overall image is quit nice, keep it up and maybe start on your next project and look back later when you have a fresh eye for things. Link to comment Share on other sites More sharing options...
gods418 Posted May 14, 2006 Share Posted May 14, 2006 nice design , very minimalist and contemporary.... anyway the background is too sharp for the cg image maybe if you blur the background or frost the glass window a bit....... and the tub looks like the floor can move and cover the tub with a push button switch.. very high tech ,, haha ... do an animation on it......... and i cant wait to see it.. very good rendering! Link to comment Share on other sites More sharing options...
kankan Posted May 15, 2006 Share Posted May 15, 2006 I don't have any issues with the render, its a nice image. The design, however, I see problems with; first of all, the view from the bathtub is quite horrible, looking at the underside of the wash-hand basin, as even the manufacturer doesn't want you to look there and they are not even normally glazed on the undersurface, let alone the plumbing connections being visible, etc. It also seems to be in the wrong location, since you have to walk across a narrow bridge of floor close to the tub to get to it. The WHB is the most commonly used appliance in the bathroom. I would get rid of the WHB from that location altogether and place it somewhere out of this image, on an opposite wall, etc. and leave the view from the tub of the clean shower only. And if you're going to rearrange the bath, then ideally, a relaxing view from the tub of the garden would be great and swap the locations of the shower and the tub and give some clear glass at low level (eye-level from the tub) with a view out to the garden. Thats my 2 cents. Kamran Link to comment Share on other sites More sharing options...
edub Posted May 15, 2006 Author Share Posted May 15, 2006 thanks for all the comments! I agree that I shouldn't cut off the tub, since it is the main subject - good call. as far as the design goes, this is an actual project for a client of ours, so I have to stay true to the design drawings as far as that goes. I'm mainly experimenting with getting the most realistic portrayal of light possible through the various openings. What you can't see off the right side is a butt-glazed corner window, and in the ceiling is a skylight. I would like to have the light come through this as well. So far I think the shower area is the most successfull, as there is a skylight in there as well. Link to comment Share on other sites More sharing options...
