anindia Posted May 11, 2006 Share Posted May 11, 2006 i am currently using 3d max 7. due to some mysterious reason i suddenly find that all my materials in the map/material browser has changed into architectural material inspite of standard. with some notifications on the top-reflectance 50%, etc. i ve tried a lot. but didn't revert them back. i don't know what is the reason. can any body tell me? actually i am in a hurry. pls. help me. vray does not support architectural material properly. i chaged each one as standard. but still its creating problem. help me pls. Link to comment Share on other sites More sharing options...
notamondayfan Posted May 11, 2006 Share Posted May 11, 2006 are u discarding the old map when u change 2 standard? sometime u can acidentally leave it as a sub map, which might (prob not) cause a prob. or maybe you could open a mat library from an old job, and just use those as a starting block? Link to comment Share on other sites More sharing options...
