Xfrog
nisus
  • 2 weeks later...
Hi,
Good to hear someone else uses Xfrog. Do you also have problems with the mappings when you import the trees in max?
Mapping seems to be out of scale and place (branches don't continue nicely)
rgds,
nisus
After clicking on the link you gave, I realized that it was for a plugin for max. I have xfrog 3.5 with an importer for max, so all the tree editing happens in a stand alone program with the trees getting imported into max. This is where I have the problem. I have inches as my units.
Hi Chad,
Only now I realise that you actually make your own trees. We do not have the time to do so. My mapping issues happen with the ready-made models.
A simple box mapping of 80x80x80 on all trunks and branches solves the problem reasonably well though...
nisus
Thanks for sharing your info guys, I just havent had time to make my own trees and just use the ready made ones. The ones I've used so far seem to be ok, Ill keep an eye open for this.
Which models give problems btw? Can you point out a tree from a library? Maybe I can check that on my dvd's.
Ronald
