claudioarchi Posted May 11, 2006 Share Posted May 11, 2006 Hello there, I'm looking for a way (recepie) for doing realistic vegetation (plants, trees, etc.) does anybody know of a plug in or something like that for LW. Thank you all see ya Link to comment Share on other sites More sharing options...
Limbus Posted May 11, 2006 Share Posted May 11, 2006 There are a couple of options. - Vue 5 Infinite (comes free with the upgrade to LW 9 if you buy vefore the end of the month) - RPC Trees and the RPC Plugin for Lightwave - Several Tree plugins. Check flay.com Florian Link to comment Share on other sites More sharing options...
richyrich Posted May 15, 2006 Share Posted May 15, 2006 you can also use hypervoxels for vegetation, very affective for hedges etc................. Link to comment Share on other sites More sharing options...
claudioarchi Posted May 15, 2006 Author Share Posted May 15, 2006 Can you elaborate on the hypervoxel technique...thanks Link to comment Share on other sites More sharing options...
richyrich Posted May 16, 2006 Share Posted May 16, 2006 here is a very quick render for you..................... in modeler laydown some points, to what ever shape you require................ activate hypervoxels in layout and use volume as your shader type and apply a crumple hypertexture to break-up the volumes. you need to size the points but you just need to experiment with this................also texture to what ever look you want...............and render :-) it takes quite a bit off tweeking though............. its a very good solution for animations as long as you dont get to close to the hypervoxels................. oh yeah, and you can use fprime but i think lightwave renders a better final image..................... richard Link to comment Share on other sites More sharing options...
Hector Posted May 17, 2006 Share Posted May 17, 2006 There are a couple of options. - Vue 5 Infinite (comes free with the upgrade to LW 9 if you buy vefore the end of the month) - RPC Trees and the RPC Plugin for Lightwave - Several Tree plugins. Check flay.com Florian There is also OnyxTree. I haven't tried it myself though. http://www.onyxtree.com Link to comment Share on other sites More sharing options...
