darkblue_wire Posted May 11, 2006 Share Posted May 11, 2006 Hi all i have tried to make lights for an interior using v-ray I don`t know the best way to do the lights ? the other problem is the harsh look allover the image .........! all critiques are welcome changes only in hsp sudives down to 20 , sigle frame , high resolution irradiance map primary & photon map for secondary all of the light are v-ray lights thanks alot & best regards . Link to comment Share on other sites More sharing options...
Brian Smith Posted May 12, 2006 Share Posted May 12, 2006 I recommend Irr. for 1st and LC for 2nd. The key is to get test renders to go quickly. Therefore, set the resolution low (i.e. around 320x240), set Irr. to Very Low, and LC subdivs to around 150. In the Color Mapping rollout, set Type to Exponential. Then insert one light and tweak other settings one at a time to figure out their affect on the scene. Then insert other lights one at a time. Any light type, standard, photometric, or vray can be used. Brian Link to comment Share on other sites More sharing options...
darkblue_wire Posted May 12, 2006 Author Share Posted May 12, 2006 Hi Thanks Alot Brain Smith for your helpful notes i have tried them all first the time go down a little after changing to light map & very low well i have changed to exponential in the light mapping the side lights is alright & still work well i don`t know what happen to the top lights ? it is looks darker do you know why ? thanks & best regards Link to comment Share on other sites More sharing options...
Brian Smith Posted May 12, 2006 Share Posted May 12, 2006 Can you post the image? Link to comment Share on other sites More sharing options...
Sawyer Posted May 12, 2006 Share Posted May 12, 2006 Try Gamma Correction bright 1/dark.4545 for color mapping. Link to comment Share on other sites More sharing options...
darkblue_wire Posted May 13, 2006 Author Share Posted May 13, 2006 Hi thanks again brain smith & thanks for sawyer attatched the image after changing dark slot under the colour mapping to .4545 i think you mean the bright i don,t know its gonna darker hey , i have rised it up to 1.5 & light multiplier to 5 its better now much much thanks for response attched the image after changes ... best regrds for all Link to comment Share on other sites More sharing options...
Brian Smith Posted May 13, 2006 Share Posted May 13, 2006 Looks good...under the Image Sampler rollout, what filter are you using...the default 'Area' filter...if this is for a still try Catmull-Rom, you're image won't be as blury. Link to comment Share on other sites More sharing options...
Sawyer Posted May 13, 2006 Share Posted May 13, 2006 No I mean lowering the dark values to .4545 (which is 1/2.2 gamma correction). Link to comment Share on other sites More sharing options...
darkblue_wire Posted May 13, 2006 Author Share Posted May 13, 2006 Hi all thanks again for the best co-operators ( smith & sawyer ) about the filter (smith ) i have changed to catmull-rom & i will attatch the result its really looks clear more the walls only harsh due to bumb map & about the gamma correction can you Sawyer please refer to any site to read about dealing with it thanks & best regards Link to comment Share on other sites More sharing options...
Brian Smith Posted May 14, 2006 Share Posted May 14, 2006 Mmohamed, The image still looks very grainy and blury (like the flowers). I'm wondering what settings you've changed from the default. If I were you, I would start over with the default vray settings by merging everything into a clean drawing. Keep the same settings for the Color Mapping and Environment rollouts. In the Irradiance rollout, change the Current preset to High. After changing the secondary bounce to Light Cache, change subdivs to 2000. In Image sample rollout, change to Fixed rate and 4 Subdivs and filter to Catmull-Rom. Don't change anything else. These settings are quite high but I'm curious to see how much it improves the quality. Link to comment Share on other sites More sharing options...
darkblue_wire Posted May 14, 2006 Author Share Posted May 14, 2006 Hi thanks for your reply ( Brain Smith ) i have max 7 & v-ray so i think you mean light map by light cash well i have already set the secondry to light map subdives were 150 changed to 2000 insted of fixed rate it was adaptive i have changed into fixed & 4 the filter already at catmul -rom & irradiance were set to medium changed to high My pc is rendering now it is very slow ( p4 2.4 & 1.0 Gb ram & 128 mb for vga ) i have to say sorry . before sending the image i take the resolution down & save to jpg & adjust it to medium so that it looks blur & the wall is already have a bumb map to look harsh ....... thanks alot & i will send the image when finished & i will try to send the file to your e-mail Link to comment Share on other sites More sharing options...
Brian Smith Posted May 14, 2006 Share Posted May 14, 2006 Change your materials to VRay materials, rather than standard. It will clean clean your image up and significantly reduce your rendering times. Right click in the active viewport to open the quad menu and select VRay scene converter. Link to comment Share on other sites More sharing options...
darkblue_wire Posted May 15, 2006 Author Share Posted May 15, 2006 Hi well ,thanks Brain Smith for comments i did the all changes & here is the result attatched ( in low resolution ) it looks nice for me i would like to know if there is anything else of the v-ray parameters to deal with .....? & if there are any details to add to enrich the image it was designed as a cinema cooridor or whatelse.. special thanks again to Brain Smith Best regards for all Mohamed Aref Link to comment Share on other sites More sharing options...
