hello
blade911
hello eveyone
im new here.,. n im just beginning to get into the 3d modelling field
i grauduated as an architect a year ago n currently working in a design firm.
anyway i wud love it if i someone cud help me by givin tips on max... or more specifically on vray.
otherwise im looking forward to spend good time on this forum
tats all for now
cheers
Hi there, if you are new to Vray you should register at http://www.chaosgroup.com/ and use their support section and look in
V-Ray docs, this contains the help index which should be able to answer any specific questions you have about V-ray settings. I would also check out http://vray.info/ and try some tutorials (the Aversis basic tutorials are a good starting place) I was in your position a year ago and these two things helped a lot, also 'the gnomon workshop' have produced 2 DVDs which are really helpful at explaining and showing you how to do interior and exterior lighting in vray and go into depth about the different GI methods as well as HDRI environment lighting.
Hope this helps and good luck for the future!
