What Could be The Problem???
Jeffrey
Hey, seriously need help here. I uploaded 2 scenes here. one scene with the door open and another with the closed door. My question is how come when I leave the door open, the whole scene goes funny, turn out black and noisy. I tried to tweak everything I can but no luck. Something wrong with the room I guess. But what could be the problem? Thank in advance~! BTW, I used Irradiance MAp and Light cache. cheers~!
  • 3 weeks later...
Maybe the background is black on the environment menu?
Yeah i assume that also, as you make an opening, the background color will work as environment and it will have some influnce to your scene ( unless you overide max at vray environment roll-out) so assume you have black background.... and try to incrrease the subdiv at irr map... maybe you can upload the setting for us.. so we can figure it together :cool:
Thanks for the replies, but how come the background on the environment menu gonna effect the interior? ANyway, I normally overide max at vray environment rollout with HDR image. I also realise it happens when there is overbiright reflection occur. Which mean nothing to do with the material but the lights coz when I remove all the lights, the scene render fine~!.. Funny huh?
If you already override the max at environment, so there is nothing to do with the background... mmm i wonder.... as I told you before, it might be better if you can upload the setting including the lighting setting....are you using vray light?
