ZFact Posted May 15, 2006 Share Posted May 15, 2006 Hi all; Anyone out there familiar with rendering out stills using cinemas 9 tile camera thing'y. Im not sure how to set it up but it would be very useful for sharing stills across multiple machines. I take it you can tell cinema to render.... say.. tile 1 - 3 on 1 machine then tile 4-6 on another and so on..... Anyone care to elaborate on the subject? Link to comment Share on other sites More sharing options...
Frosty Posted May 15, 2006 Share Posted May 15, 2006 Check my tutorial here>> http://www.crucialperception.com/free/tutorials/image-tiling.pdf Link to comment Share on other sites More sharing options...
ZFact Posted May 15, 2006 Author Share Posted May 15, 2006 Thanks Steve; Only problem is i cant seem to locate the 9 tile ands the 25 tile camera.... there is an option for tiled camera but!!! I have brought this into my scene but i cant figure out how to control the tiles... maybe im in the wrong area altogether! Link to comment Share on other sites More sharing options...
Frosty Posted May 15, 2006 Share Posted May 15, 2006 Read the tutorial a bit more carefully. The tiled camera is nothing more than an expresso script. Highlight the script and check its attributes. Link to comment Share on other sites More sharing options...
ZFact Posted May 16, 2006 Author Share Posted May 16, 2006 Sorry Steve; Im a wee bit lost.... How do I change the tile camera into a 9 tile or 25 tile camera. I cant seem to locate that setting. If i can find this i should be able to figure the rest out myself.... hopefully! Cheers Link to comment Share on other sites More sharing options...
Frosty Posted May 16, 2006 Share Posted May 16, 2006 ZFact said: How do I change the tile camera into a 9 tile or 25 tile camera. I dont think you can...without tweaking the code. Thats how Dan Stubbs made the 25 tile camera. As far as I know you have to add the other camera for the tag. The entire refocusing of the camera is set up in that expresso tag. Link to comment Share on other sites More sharing options...
ZFact Posted May 17, 2006 Author Share Posted May 17, 2006 Im lost; Within my object library there are no options for a 9 tile or a 25 tile camera... the only option in there on my system is for a "tiled camera" if i select that do i then select the number of tiles (9 or 25) within the xpresso tag? If so where is it my good man? Link to comment Share on other sites More sharing options...
Frosty Posted May 17, 2006 Share Posted May 17, 2006 Its possible we are on different versions of the software. I'm using 9.1 - is it possible that 9.5 changed how this worked? Link to comment Share on other sites More sharing options...
edub Posted May 17, 2006 Share Posted May 17, 2006 I'm using 9.6 and it's there still: Link to comment Share on other sites More sharing options...
Frosty Posted May 18, 2006 Share Posted May 18, 2006 That solves that. I suggest you re-install and/or contact Maxon support. Link to comment Share on other sites More sharing options...
