wireframe material
only3d
hi evryone
im trying 2 render an object with its wireframe only, but when render the image only the shadow appears wired while the object itself remains solid.
ive tried doing it with a fresh new file and no fiffling with the settings and yet the result remain the same.
worth to mention that im using a standart mateial only and nothing else.
so is there something wrong in what im doing or is there a completely different way of doing that which i dont know of?
heres a jpeg of what i got..
tnx
As far as I know, there is no way to render wireframe only within vray. If you change the renderer to the default scanline renderer for this particular purpose, there is a checkbox under the renderer tab that says "force wireframe". If you check that, I believe you will get what you're looking for.
cheers mates!
i think i got it
used the opacity channel instead of transparency, seemes more logical 2 me.
came out pretty splotchy but anyways i decided 2 go with stndrt mat with tiles in the opacity channel.
seems easier 2 me w better results and much more control over the wire of the object. (my object being much more complicated than a box..)
still many tnx's!
till next time..:)
