fernandoc Posted May 18, 2006 Share Posted May 18, 2006 Hello everyone, Is there a way in Autocad to pass from a single view port to multiple viewports and go back to a single viewport and so on without loosing the multiple viewport configuration? For exemple, if I set the UI to 4 views (plan view, side view, front view and axonometric) then I want to have only the plan view in the hole UI then go back to 4 views with the same configuration I had, then have the axonometric view to take the hole UI and go back, and so on. Every other 3D software I know has this. 3D max has it, in Maya just use the space bar to toggle between single and multiple viewports, in XSI it's with th F12 key, in Form-Z it's with the W key, etc... Thanks for your help, Fernando Link to comment Share on other sites More sharing options...
Brian Smith Posted May 18, 2006 Share Posted May 18, 2006 Desktop does this essentially with sheets. Just have a sheet with 1 large viewport and another with four smaller ones. But no, there is no way to do it like Max does it. Link to comment Share on other sites More sharing options...
fernandoc Posted May 19, 2006 Author Share Posted May 19, 2006 that's too bad.. Thanks anyway Brian cheers Link to comment Share on other sites More sharing options...
