gdamaso88 Posted May 18, 2006 Share Posted May 18, 2006 This is a problem get using vray. I render small image and the textures appear to render as they should. When I go to render the image at higher resolution the textures are lost and don't render correctly. When going through the prepasses I show the calc phase it seems to pick up the texture until it renders the final image. Does anyone have any ideas? Link to comment Share on other sites More sharing options...
aaron-cds Posted May 18, 2006 Share Posted May 18, 2006 What software and what build? This happens with viz 2006 and a vray build other than 1.46.15 Link to comment Share on other sites More sharing options...
Ray Posted May 18, 2006 Share Posted May 18, 2006 ^ what he said. I had to get chaos to send me 1.46.15, now I have no trouble with textures showing up (except when I forget to copy some to the shared drive folder for DR.) Link to comment Share on other sites More sharing options...
Island J Posted May 18, 2006 Share Posted May 18, 2006 Is anything significant lost when you downgrade? like the light cache? Link to comment Share on other sites More sharing options...
Ray Posted May 18, 2006 Share Posted May 18, 2006 I couldn't tell tell you, because I barely had a chance to use 1.47 before the bug hit me and I had to switch. Link to comment Share on other sites More sharing options...
gdamaso88 Posted May 19, 2006 Author Share Posted May 19, 2006 i'm using viz 2007 and vray 1.47.03 i had this problem also with viz 2006 on chaosgroups website the call 1.47.03 the only stable build and the 1.47.15 a demo build is it possible to authorize the a demo build or do i have to email them? does anyone have an examples of this happening to them that they can post? Link to comment Share on other sites More sharing options...
classix Posted May 19, 2006 Share Posted May 19, 2006 check Your windows region settings. Settings other than decimal dot may cause errors. Link to comment Share on other sites More sharing options...
classix Posted May 19, 2006 Share Posted May 19, 2006 check your windows region settings. Settings other than the decimal dot may cause errors. Link to comment Share on other sites More sharing options...
FlytE Posted May 19, 2006 Share Posted May 19, 2006 is it possible that you are accidentally applying the old irradiance map for your smaller render to your bigger one? Link to comment Share on other sites More sharing options...
Trevor Tizard Posted May 19, 2006 Share Posted May 19, 2006 If you send an email to Chaos they will send you 1.46.15 which works fine with Viz. We are all hoping that these glitches will be addressed soon! Hope this helps. Link to comment Share on other sites More sharing options...
gdamaso88 Posted May 19, 2006 Author Share Posted May 19, 2006 here's another try only 800 x 600 and I still got the error. I also tried switching from qmc to light cache. Link to comment Share on other sites More sharing options...
