I cannot see the transform gizmo
fundagenie
HI guys
I am using 3d max 8.....i was working on a file and suddenly i can't see my transform gizmos anymore-move,rotate or scale......I tried hitting X key but nothing is happening....i can move , rotate and scale the objects around but have to constantly use the f5,f6,f7 and f8 keys -- which is a headache as i keep switching the viewports....
In the Preference settings>Gizmo -- transform gizmos is ON and everything is in default since i never played around with it....
I have restarted 3d max,switched to default UI scheme and finally even reinstalled max...but the problem remains...is there any hotkey to hide the transform gizmos as such....which i might have accidentally pressed......
or is there any other technique to get back to normal.....
Regards
FJ.....
Hi Tanni
I pressed X......but as i had mentioed earlier there is no gizmo to be seen anywhere in the viewport.....
It just vanished off suddenly while i was working........on pressing X gizmos are either enabled or disabled but you can still see it in the viewport.....here there is nothing....
Regards
FJ....
