otoperia Posted May 21, 2006 Share Posted May 21, 2006 max dont want to render, its turning off when counting lightcachand sending me error message. troble is in grass displacement, and its uvw mapping, i think so, when i am hiding a grass object, its rendering, and when i am hide everything but not grass, its rendering too, but both cannot render. but the strange thind is thet, i am rendering on dual xeon 2.8 , 4G ram, quadro fx video, and its turning off, but when i am rendering thet scene on P4 3.6 andP4 3.0 its rendering . so help me plz if you know something about this problem. here is render before start erroring. Link to comment Share on other sites More sharing options...
skippy Posted May 21, 2006 Share Posted May 21, 2006 Hei! I bealeave you are running out of memory. Its usual with discplaced grass. 3gb switch, render setting etc....good luck! Link to comment Share on other sites More sharing options...
otoperia Posted May 21, 2006 Author Share Posted May 21, 2006 hey hey i dont understand, your telling me thet its memory troble, i have 4 g ram, and i think its not thet, and what i must switch plz , tell me, i dont understand Link to comment Share on other sites More sharing options...
Brian Smith Posted May 21, 2006 Share Posted May 21, 2006 You're going to have to do more testing to figure out the problem. The things you did do not give enough information for someone to be able to say for sure what the problem is. Test a very small area of your grass. Create a new scene with nothing but the grass. Change the light cache Subdivs to something like 50 and see if that will render. There's about a thousand things you can do to figure out the problem deductively. Also, keep the Windows Task Manager open and watch what's going on with your RAM the entire time. Link to comment Share on other sites More sharing options...
drvox Posted May 28, 2007 Share Posted May 28, 2007 max dont want to render, its turning off when counting lightcachand sending me error message. troble is in grass displacement, and its uvw mapping, i think so, when i am hiding a grass object, its rendering, and when i am hide everything but not grass, its rendering too, but both cannot render. but the strange thind is thet, i am rendering on dual xeon 2.8 , 4G ram, quadro fx video, and its turning off, but when i am rendering thet scene on P4 3.6 andP4 3.0 its rendering . so help me plz if you know something about this problem. here is render before start erroring. Hi Otoperia, Did you fix your problem? I'm haveing the same prob here... when building light cache I get out of ram...I have 2Gb in this intel core 2Duo. Otherwise, in my laptop, a centrino of 1,6Ghz with 1,2Gb I can render the scene... Any ideia? Im also using vray displacement for grass..but if delete it I can't render too... Thanks, King Regards Link to comment Share on other sites More sharing options...
